Question: how to find d.water to coolant ratio
Balto, MD
So I'm draining and filling the coolant. What temp rating should I be looking for once the mixture is done? As in what freeze point should I have in the end. I'm located in MD.
Get an empty gallon jug. Use your best guess to sharpie a line halfway up. Pour half your AF in there. Then top off with water. Top off your AF jug with water. Pour approx a quart at a time from each vessel into the car until it's used up. If it's not, pour the temp jug back in the AF jug and mark it 50/50.
You'll be magically close to 50/50 even if your sharpie line's a little off.
You need the 50/50 for corrosion protection and boilover as well.
50/50 is standard for everywhere except places that get below -30. For colder places that get below -30 in the U.S. or Canada, people generally go to 60/40. 50% coolant mix protects to -34.2 and 60% protects to -63 degrees. There are few places in North America that get colder than -63.
http://www.engineeringtoolbox.com/ethylene-glycol-d_146.html
The all-time record for Minnesota was set on February 2, 1996 in Tower where it got to -60.
Can I use a standard coolant hydrometer for OAT ELC coolant, like Zerex ZXED-1.
I wasn't sure if it would work since it's not glycol based
OAT is ethylene glycol it just has different additives.
IDK about "Sierra", the propolyne glycol, if they even still make it.
I would not trust the floaty balls. Just mix it right.
Yes, that would work, but it isn't very precise. If you want good precision, get a refractometer like this one... https://www.amazon.com/gp/product/B0089EEWYE
