Does your oil pressure gauge seem accurate to you? I recently bought a 2004 GMC with the Duramax and it was very well maintaned and runs excellent. The truck has Amsoil 15W-40 in it and has been changed at every 10K miles and was recently changed just before I bought it. The truck has 111K miles on it.
The gauge is well over 60PSI at idle when cold but once it is warm it just seems to go lower and lower. The gauge goes to 120PSI so when it gets to the low side of the gauge it is still reading about 20-25PSI at idle. It jumps right back up as soon as you give it some throttle but the low idle pressure makes me nervous and was wondering if any of you with a Duramax have seen the same thing on your gauge. The engine runs great and makes no noises to indicate poor oiling at idle but I am curious if this the norm with these trucks?
