This is a topic I don't know much about.
I have recently had what MAY be a cause for concern with my current fill of oil, which is coming up due to be drained anyways, but riddle me this..
Is it a problem that a few days ago my car was operating on 3cyl, dumping gas (assuming the injector was still running on that cyl) into the cylinder during a period of about 15-20km (10-12 miles) where I had to limp it home?
The problem was a bad coil, which was fixed right away and its working fine now.
But, should I drain the oil out early because of this? It was probably a good 30 minutes of running on 3 cylinders, the whole time dumping unburnt gas into my #1 cylinder.
Thoughts?
Thoughts?
