Hi,
I have a '01 Acura MDX that calls for premium fuel, has a knock sensor and the ability to retard timing in case of detonation.
It has 64k miles on it right now. I am the second owner so I don't know what the first owner used for fuel and oil but I can tell you that after 10k miles under my ownership its a whole different beast now.
Recently I have been monitoring how the timing behaves on it with different octane fuels (using an obd2 scanner).
I was surprised to find that even with 92 or 93 octane fuel the timing did retard consistently under load and acceleration. Do note that I have never experienced any audible pinging even with 87 octane fuel.
I once did a compression test and the results came out at about 235psi, all 6 cylinders very close, which I feel is on the higher side. Then I did a seafoam treatment (IM vac line method) and noticed a slight drop in the compression - 210psi this time. looks like some carbon did get removed! However, I am not quite satisfied with the cleanup just because of the way the vac line is positioned in the IM I think maybe it did not clean up all cylinders pretty good.
Also I was a little cautious and conservative with the amnout of seafoam going in as this was my first time doing it so that might have been a factor too.
Long story short, I think the timing retard I am getting even with high octane fuel is because the combustion chambers still have carbon and they could use some more help.
This time I am thinking about doing the piston soak method.
Questions -
Will the piston soak remove the carbon from the walls and top end also or just the piston head ?
Typically what causes excessive carbon ? I guess rich mixtures ? Incomplete combustion (sparkplugs ?) Type of oil ? Does timing retard have anything to do with it ?
Questions -
