Quaker state atf
Kalamazoo, MI
What do you know about the quality of quaker state dexron III atf? Is it any good? I have been using Valvoline with no problems, but saw gallon jugs of quaker state for $6.77.
Any help would be appreciated.
When it comes transmissions, fluids are the biggest concerns unlike engine oil. A lot of transmissions have different requirements. If your current method of using Valvoline has worked well in the past, I would not be inclined to change it just to save a few bucks. This is one of the times where if you find something that works, stick with it.
For daily drivers, any OTC fluid changed within 30,000 miles should be ok.
Preop the fluid change with Auto-RX.
Also conisider one of the Sponsor's ATFs.
