PYB in 2011 Fusion
I didn't know the new Fords even had OLMs. The '10s didn't. I simply go by calendar: 6 months for both my rides. I don't reach the mileage before then.
Our '10 Fusion does, but it's simply a counter. Goes off after 6 months/7500 miles.
Originally Posted By: troberts
The "oil life monitor" in late model Ford products is simply a calendar (6 month countdown)and mile counter (to 7500 or 10,000 in the hybrids) and in no way is as sophisticated as GM's OLM.
That's not the case in a 2011 Fusion (and some other 2011 cars). It actually does have an OLM, and it is similar in logic to the one GM uses. Pre-2011, you're correct.
Check it out here.
Originally Posted By: JeepRubicon2k3
Originally Posted By: Ram01
PYB will sludge that 2011 motor up use Quaker State instead
:DOH:
Originally Posted By: lexus114
but it just say`s ok. does not give a percentage like gm`s do?
I think it gives a warning @ 5%, then another at 0%. I would imagine that you can do a system check at any time (like older Fords) and check the status, but I don't know for sure.
Pennzoil Conventional will sludge that 2011 motor up use Quaker State instead
You better be kidding. As far as the oil... Pennzoil Conventional is fine...but the Motorcraft is a Ford product.
Slightly Off Topic:
I was killing time before catching a plane out of Houston, Texas earlier this week and I saw a Ford dealer with many new Fusions on the lot. I took a good look and I really like the car (it's really nice in red). The only thing I don't like (which applies to virtually all car brands today) is the 17" low profile tires that come as standard. I feel they will be expensive to replace when the time comes (as opposed to basic 15" tires like 205/65/15).
The Fusion is a very, very nice car,IMO.
Run whatever oil you want that meets the viscocity and brand-specific approvals (if neccesary) that your car needs.
In other words, read your owners manual, and follow what it says to a T - you will be fine.
Pennzoil Conventional is a fine conventional oil. MC is a great blend for your money. Any 5w-20 will probably meet the required spec's for your car and give you the required protection.
Originally Posted By: oilchangeguy
any issues in running Pennzoil conventional 5w20 in a brand new 2011 Fusion with 3000 OCI's? Also using Motocraft filters.
Thanks!
its a fine choice, but if you are changing it your self mc is almost the same price at wal mart. and its a blend.
but why not syn? the prices are right on PP and mobil at wal mart. i think PP is like 20 for a 5 qt jug. with the 3.67 for the mc filter thats still cheaper than anything at an oil change shop.
if it were me i would use a quality syn from a company you trust. its a brand new car, stop as much wear as you can and protect your investment.
just my opinion
Originally Posted By: ARCOgraphite
US "syn" is just high detergent highly refined conventional oil.
What's wrong with that? PP has turned in outstanding results. Pennzoil Ultra even better. Can't recall anyone complaining or having a problem with it IIRC.
