Put Bilstein 5100 on my 2019 Tacoma
The 5100s for my truck don't have any external springs and I can't see how they could affect ride height. Trying to decide between 4600s and 5100s.
I have 5100s on the front of my Tacoma. The front ones can affect ride height. They have a 3-setting perch for the spring to sit on. Normal (stock) height, medium lift and high lift. I have mine on the normal (stock) setting.
They have a really nice ride. Not sloppy and not hard or aggressive.
If you're trying to decide between the 4600 and 5100's make sure and contact Bilstein first. In a lot of cases, if you're not doing any height adjustment the 4600's are valved the same as the 5100 and will save you some $$.
They are basically B6 shocks for SUV’s and trucks. I have B6 on BMW, and they are phenomenal shocks. I daily and track that car.
I just got rear B6 for Honda Pilot as one has small leak.
I think I'm due for something. Took a long highway drive yesterday (2hrs each way) and rougher parts were bouncy and a rough ride. Bridge joints sent me airborne. Shock are original and 12 years old, but only 52k miles. It passes the bumper test, but its pretty hard to bounce a 3/4 ton truck, even at my size. I'd like for it not to feel like its crashing over every pebble. (crashing - get it? hahah!)
Pablo - have you found the ride is softer, or stiff but controlled?
How is the tread on your tires? My Hankook Dynapro ATMs need to be replaced and the ride is less than pleasant.
I had 5100s on my 2009 F150. I have 4600s on my 2016 F150. I don't have a lift or level. The 4600s feel the same as the 5100s. For esthetic reasons people may not want the 4600s as they are very yellow/blue whereas the 5100s are silver.
The tires are about 1/2 worn out Firestones that are horribly balanced and egg shaped. Will be changing these out shortly as well. I've had bad luck with Firestones in the past but these are possible the worst tire I've ever encountered.
Shock Surplus has some good YT videos going over the differences between the Bilstein lines. You will never notice a difference between 4600 and 5100's really. You will be happy with either. The 4600 are Yellow, the 5100 are Silver. A lot of people don't like the yellow look for the 4600s, but they are wonderful shocks.
I only have the rear shocks on right now. But I just decided to save money getting the 4600s. I was going to play with leveling etc. But just decided to stay stock, and keep the front a little lower like it is from the factory.
My theory is per my request make it level
So either the backs were really shot or he adjusted the fronts
It aligned perfectly
shocks in the rear will not change your ride height. he changed the ride height in the front.
I have owned and installed several sets of both. In my personal experience, there are differences between the 4600 and 5100s. A long time ago I wrote bilstein about this, and depending who I reached, got different answers. Some would say they were the same. The guy that told me they weren’t the same, sent me the numerical numbers to prove it.
What I learned and experienced:
- they are both progressive shocks. They stay stiff until they take a hit, and then let them open up until they slow down, then stiffen up again. The 4600s in my sons 2019 4R are very well tuned for that vehicle, if anything they open up a tad too easily, because once you get them floating they can and do float.
- the 5100 has less rebound dampening than the 4600, while having close compression dampening. This means that on rough ground they tend to “inflate” and keep the vehicle a little higher. It also means, however, that in rhythmic bumps they tend to “pogo,” and lift the truck up at every bump and float down. This is exprremely unsettling on concrete interstates when it feels like the vehicle is off the ground at every bump.
- the 5100 really needs to see a small lift to feel right. I say this because it essentially has an internal hydraulic bump stop in the bottom 2”. Or at least 2 sets of rears I had, did. You could feel it because on a non-lifted truck the “contact” really felt like hitting a bump stop, and it happened in everyday driving - it felt like I’d lost some suspension travel with them. This was “discovered” when compressing them by hand - which isnt the easiest to do, and by golly while shoving it downward it would hit a “catch” at the bottom 2 inches.
All this to say, I still like the 5100s, but because of the weaker rebound dampening, I would only advise using these as a set for 4; not doing a “rear only” job.
Bilstein makes good shocks. Gotta choose the right one for the application.
