Yeah I agreed with Subie's reply about that earlier ...
Are N52s stronger than samarium cobalt?... I made my post before I read Subie's post, so we were thinking the same thing.
If one were so inclined that could even be part of the testing… run filter for say 5k & pull sample; install samarium magnets & run additional 500 miles & pull sample; remove samarium & install N52s and run 500 miles & pull sample. Wait for results & perform OCI as indicated by N52 oil serviceability results.
That way one isn’t waiting until the end of the OCI where the possibility of a loaded filter exists, and it becomes progressively harder for the magnets since part of the ferrous material will already be removed, meaning less circulating material when the N52s are installed therefore a lower likelihood that they will improve the PC unless they’re stronger & doing a better job than the previous magnets. If the PC doesn’t improve, you can conclude the SC magnets are collecting more material than the N52s…. Sound plausible?
Thanks! I figured you had done deeper research. IOW there’s somewhat weaker magnets that will live in the environment, or strong ones that will lose their magic when hot.N52 grades have more energy product but in contrast to say N42 or N45, they are more thermally sensitive to magnetic strength loss when heated above their max operating temperature which are typically around 80 Celsius, assuming the average oil temperature is around 100 Celsius plus or minus... Charts are comparison of magnets with the same dimensions but different grade (3/8" diamter x 1/8" thickness)
This is why I avoided using off the shelf common grade Neodymium magnets in favor of N42SH grade and Samarium Cobalt disc.
The more common non high temperature grades will work fine but will overtime permanently loose their strength slowly from repeated heat cycles. N42SH and other related SH grades are typically rated at 150 Celsius in their maximum operating temperature.
Problem is high temp grade magnets aren't cheap and not many online vendors have a wide selection to only a few options available.
The N42SH bars cost me about 4 bucks each at the size of 2" x 1/2" x 1/8". The non SH grades cost around half of that at the same size.
Also another reason to avoid those oil filter magnet vendors as they are making massive profit margins and probably use cheap grades magnets than sourcing your own is miles cheaper with you having an actual choice and shape to pick from for your application...
A BITOG user did multiple particle counts with and without a Filter Mag, using the same model of oil filter. See this post.Although you’re not going to get an accurate representation of the filter by using the magnets. If you want to get the best data, you’d run almost your full OCI on filter alone & pull sample. Then add magnets and pull another sample 500 miles later. That way you can separate the effect of the magnets vs the filter itself. You may well find that the magnets are more effective on some filters than others… I’d bet the less-efficient filters would end up with more on the magnet, but that’s a WAG at this point.
Great info! BTW is the samarium cobalt the strongest that will live at 150*C, or is it the best balance of price to performance?
The testing done by Ascent Filtration a few years ago to ISO standards showed that the Boss was 99% @ 46u IIRC. Its efficiency curve was quite shocking compared to those that were 99%@20u.Some thoughts on the information here - a blank sample of the actual virgin oil should also have been tested along with the 500 mile oil sample. Note, the final filter micron rating of the oil manufacturing process is also unknown. The lower (under @20 micron) particle data is not meaningful if the oil is processed through 20 um final filtration (as an example) at the manufacturer, without blank sample data.
Additionally, the filtration efficiency of the PBL filter should not be concluded as sub par based on the data. If the nominal micron rating of the filter is 20 um (as an example), then the filter is doing an exceptional job filtering larger particles out and/or the engine is not shedding too many larger particles.
It was 99% @ 35u in Ascent's ISO 4548-12 testing. It drops off to 62% @ 20u. The Purolator Spec Sheet shows 99% >46u.The testing done by Ascent Filtration a few years ago to ISO standards showed that the Boss was 99% @ 46u IIRC. Its efficiency curve was quite shocking compared to those that were 99%@20u.
500 miles with virtually no oil filter would have a low particle count. The longer the oil us ran, the more contaminated it becomes if there was no filter.The data here, albeit single data point and only over 500 miles, indicates exceptional real world filtration performance.
It doesn't matter how many of particles there are in the virgin oil, since the oil will get passed through the filter thousands of times in 500 miles. Even a filter that is only 20% efficient will reduce the number of particles in the oil by more than a factor of a million after only 100 passes through the filter.Some thoughts on the information here - a blank sample of the actual virgin oil should also have been tested along with the 500 mile oil sample. Note, the final filter micron rating of the oil manufacturing process is also unknown. The lower (under @20 micron) particle data is not meaningful if the oil is processed through 20 um final filtration (as an example) at the manufacturer, without blank sample data.
Depends on how dirty the virgin oil is, and what sized particles are in it and the efficiency of the filter. I'd imaging most virgin oils from big brand name oil makers is pretty clean out of the bottle, not enough contamination to really worry about. Think there have been a few PCs done on virgin oil in the VOA forum.It doesn't matter how many of particles there are in the virgin oil, since the oil will get passed through the filter thousands of times in 500 miles.
Again, depends on the filter's efficiency and the size of the particles. Particles 20u and less actually do the most wear. Filtering out the debris above 20u helps reduce added smaller debris if those got crunched up in the running engine into smaller particles. Inefficient filters are pretty bad capturing and retaining particles less than 20u. Look at the Ascent ISO efficiency test curves - HERE.Even a filter that is only 20% efficient will reduce the number of particles in the oil by more than a factor of a million after only 100 passes through the filter.
The particles in the oil are basically all the particles that the filter can't catch and retain - the oil gets sent through the filter over and over throughout the OCI. As we know based on past discussions, as oil filters get more loaded up with debris and the dP increases, they become less efficient due to debris sloughing. So that, combined with more and more particles being introduced over the OCI results in the oil becoming more dirty the longer the OCI. A high efficiency filter (which do no slough as much - that's part of their high ISO efficiency rating) is most advantageous the longer the OCI is. Last thing someone should do it use a low efficiency filter that has a high mileage use rating.The particles that end up in the used oil sample are those that have been recently introduced by the engine and haven't had a chance to make many passes through the oiling system. The particle concentration hits an equilibrium based mainly on the rate of introduction of new particles and the efficiency of the oil filter.
Officially, yes.Don't mean to hijack a post.
Is the efficiency of the Purolator BOSS PBL22500 still around 40 microns?
Thank you very much..
That’s not true. Maybe if he’s trying to determine more exactly how efficient the filter is. A particle count can help determine if the oil is remaining clean enough. That lets him know if what he’s doing is working and he says he’s going to do another Particle count later. He can compare it with this one.The data is meaningless without a blank virgin oil sample, period. We have no clue of the final filtration step of the oil manufacturing process.
