- Joined
- Jul 28, 2024
- Messages
- 2,120
anyone use or familiar with the brand?
Even if it's a good charger/maintainer, don't expect anything from the pulse function. Think marketing.
Seems like an ok charger focused on a mildly useful gimmick
I'd go Ctek, optimate, or a few others before them.
If you are experiencing a loss of capacity or battery not holding a charge, could be a sign of a battery experiencing sulfation.I think the pulse is for desulfation. I am thinking there are certain conditions of sulfation where it could help and others either not much or not at all. Not sure a battery owner can determine that.
BatteryMinder techs told me it can take a few weeks to revive a sulfated battery.
It took a month to restore a 3 1/2 yr old battery from soh 65% to 100%. I wasn’t sure I could get there.If you are experiencing a loss of capacity or battery not holding a charge, could be a sign of a battery experiencing sulfation.
I read in the Battery Minder instruction manual, that it can take 2 to 4 weeks of continuous use for the desulfation process to complete.
I have also seen this quote in their IFU:
NOTE: Do not expect to completely dissolve sulfate in a day. Long established sulfate will require a longer period to be completely dissolved. Be patient, and you will be rewarded with a "sulfate-free" battery.
Good point. I own a Battery Minder 2012 AGM and 128CEC2, and recently purchased the Battery Minder "wall wart" 12117TC to try out. I noticed it can run on the charging mode for long periods of time...longer than I was conformable with...I saw over 20 hours running at 14.82v (temp compensated in a mid 30F garage), before I unplugged it and called Battery Minder customer service rep. "Dave" the CSR said this was normal operation and it can run for up to 3 or 4 days before it drops to float mode, then maintenance mode, depending on battery condition. I found this odd, since this battery is normally maintained on a 2012 AGM and tests fine. The regular Battery Minders never run more than 4 hours in the charge mode before reaching maintenance mode, on an otherwise healthy, charged battery.By the way, don’t buy the cheapo Northern Tools version of the BatteryMinder since it is by name only and does not use the same algorithm as the Standard BatteryMinder. This is from BatteryMnder customer service when I questioned them.
Does it data log? I'm too lazy to keep checking it constantly...
Pulse Tech doesn't temperature compensate. I was about to buy one, until I read the instructions for use and product sales sheetThis charger looks interesting I must say. If it actually works. I searched their website and I don’t see any info on if this thing adjusts to outside temp?
No data logging.Does it data log? I'm too lazy to keep checking it constantly...
I'm probably going to just buy another 128CEC2. I'm not too worried about the 12117TC, I purchased during a sale last fall and only paid about $25, perhaps $30 with shipping. I may just box it up and flip it on eBay.
Correct.Pulse Tech doesn't temperature compensate. I was about to buy one, until I read the instructions for use and product sales sheet
Otherwise it looks like a decent product.
Details here:
https://pulsetech.com/products/xtreme-charge-xc450-battery-charger-maintainer-and-conditioner
Well, then I’m out. I had one in my cart but considering I’d be using it in some pretty cold and sometimes hot temps it doesn’t make sense. I’ll just stick with my Nocos and the cheapo Axtra that charges my mower and toys.Pulse Tech doesn't temperature compensate. I was about to buy one, until I read the instructions for use and product sales sheet
Details here:
I think for the price point ($40), this four amp Pro Logix looks promising. Has temperature compensation and works on all chemistry types, including lithium Ion. Only question is how effective the desulfation mode is. The desulfation mode is not continuous like some brands, instead it detects a certain parameter that must be met, then it will run that mode before completing charging and maintaining.Well, then I’m out. I had one in my cart but considering I’d be using it in some pretty cold and sometimes hot temps it doesn’t make sense. I’ll just stick with my Nocos and the cheapo Axtra that charges my mower and toys.
I looked at the pro logix and it pretty much checks all the boxes. The pulse tech seems to be a proven charger to bring batteries back from the dead. I was able to restore a 4 yr old Everstart maxx that had spent its entire life in my Nissan that has smart charging, which means that the battery is constantly running around on an about a 50% charge with my genuis 5. It took several runs in the repair mode function, but I was able to get the battery back to 95% SOH and take a charge of 90%. Prior to, the SOH was 45% (replace battery) and wouldn’t charge over 55%. My nephew installed the battery in his work car and just made it through a week of negative temps. I still may get the pulse tech, but I’m going to reach out to them about using it in cold Ohio winters and 95 degrees in the summer. If they use these for the military, you’d think that some thought went into this.I think for the price point ($40), this four amp Pro Logix looks promising. Has temperature compensation and works on all chemistry types, including lithium Ion. Only question is how effective the desulfation mode is. The desulfation mode is not continuous like some brands, instead it detects a certain parameter that must be met, then it will run that mode before completing charging and maintaining.
https://www.amazon.com/Clore-Automo...575851&ref_=pd_hp_d_atf_ci_mcx_mr_ca_hp_atf_d
Like Battery Minder, it will resume charging after a power outage.
The lowest price Battery Minder (online) is around $92 with free shipping, and no tax.
This one is for flooded and AGM batteries. They make a separate model specific for Odyssey AGMs.
https://www.batterystuff.com/batter...2-amp-charger-maintainer-desulfator-2012.html
