My daughter drives a 1987 Celica GTS. The rack and pinion just blew out on this car and fluid is pouring out of the right boot when the engine is running. I plan to replace the rack, but my question is about which fluid to use in this car. The PS reservior calls for Dexron II type PS fluid. The PS system on this Celica has been leaking for some time now, and I think she has been putting Dexron VI in there to fill the reservior.
I've read in some places that you should not use Dexron VI in a power steering system that calls for Dexron type fluid because it can cause seal failure such as what we have experienced on this car. Is this factual, or is this bogus information? If it is true, then what should I use in this car? I can't find Dexron III anywhere around here.
