Originally Posted By: Trav
On these I just disconnect the return hose, put a piece of clear tubing on it and have someone start the engine while i fill it, It gets 100% changed in about 10 sec.
Ford pump whine is well known, the answer is to vacuum bleed them, they go quiet.
Can you give more details on this? I have an '01 Ranger with this issue. Thanks.
Sure. Make this little tool for hand held vacuum pump, its a rubber stopper from the hardware store and a piece of 1/4" hard nylon tubing cut one end with a slash tip to allow it to go through the stopper easier.
Drill a hole through the stopper, lube the tubing with WD40 and put it through the stopper until about 1/2" is exposed at the end. Mae sure all connections are tight and leak free.
If your reservoir has just a round filer neck size the stopper to fit snugly in the neck if it has a cap with ears size it so it covers the top of the neck completely.
If your reservoir is remote like on the fender well the next part is easy, start the car, remove the fill cap and insert the stopper.
Pump the vacuum until the pump just begins to make a noticeable change in noise and leave it there under vacuum for 10 min. Turn off the engine and let it sit under vacuum for a few hours or even overnight. You may need to pump it once in a while as the air comes out.
On engines with the reservoir on the engine in the weeds behind belts and hoses, starting the engine is not an option, just pump up about 15in vacuum and leave it.
This will quieten many pumps especially Fords or new pumps that have air and make noise at install or quiet pumps that got noisy after replacing fluid.
If it doesn't mechanical repair is indicated.
