PROTEC PXL 51358 CUT OPEN
In the shop
This oil filter and NAPA Syn was off a friends 2018 Nissan Sentra. Had 6k on oil and filter. Put a tough guard and some Mobil 1 5w30 in. Car has 65,xxx on it. Date code was october 3, 2022 also.
Looks decent to me @6k miles. And normal M&H Puro attached flat spring dome bypass. The PXLs posted with the detached bypass/compression spring combo like Champ Labs/Fram something new from M&H. Still made in the US. (y)
Thanks for c&p.
Thanks for c&p.
Yeah, I’m kinda wishing I had got case of these from RockAuto.
Off topic: I found the dome end bypass spring on the Puro tech filter interesting also. What do you think of that?
I meant this one
That's not a bypass spring. That's the "leaf spring" that holds the filter guts together. Something Purolator uses in most of their filters. That one has 4 smaller legs, so might make it more "springy" than the ones without "legs".
Very god Zee. Thank You for this 👍🍻
