- Joined
- Nov 29, 2009
- Messages
- 9,526
Do you turn the regular up all the way to seat the tire bead? Like 100psi or so?
I just use soapy water and haven't had to go over max inflation on a tire yet, to get it to seat all the way.I was just talking about the amount of air to use for it to actually make contact with the rim and actually seat the bead
Well actually take on air is what I meant, not just blow it out the sidesI just use soapy water and haven't had to go over max inflation on a tire yet, to get it to seat all the way.
Oh, on real tires I have to use the ratchet strap as I have a small compressor. On my mountain bike, next time I will turn down the regulator, as I think I did get close to blowing up a tubeless tire! It was looking a bit large for a moment!Well actually take on air is what I meant, not just blow it out the sides
I just had the tire shop mount a couple mower tires I bought like 4 years ago as spares, one of them was folded in quite a bit and didn't want to seat. He sprayed some soapy water in the area and she seated right after! I think it takes a while for them to slowly come out of their folded up storage state, but it will after about 20 seconds or so it seems.Oh, on real tires I have to use the ratchet strap as I have a small compressor. On my mountain bike, next time I will turn down the regulator, as I think I did get close to blowing up a tubeless tire! It was looking a bit large for a moment!
I've heard, but what happens when it seats real quick. Does it break the strap?BITOG taught me about the ratchet strap method and that was the cat’s meow last weekend dealing [again] with a deflated ZTR steer tire which totally came off the bead and wouldn’t press outward enough to re-seat. Great method!
-m
No, but you don't want to go crazy giving it the beans, either. You should have the pressure regulated down and stop to loosen the strap as soon as the bead starts to seal.I've heard, but what happens when it seats real quick. Does it break the strap?
