Propane Heater.
Originally Posted By: Donald
I bought one at HomeDepot and it seemed scary to me. Too easy to knock over and start a fire. I returned it.
These type of heaters have a tip over shut off feature. Also I place my tank in a square plastic milk box for additional stability.
Originally Posted By: ARCOgraphite
How much CO come off these things?
A lot.
There was a story in the news last year about a family living in a trailer that was using one of these for heat. They didn't make it.
A lot.
As with any gas heating system you have to be safe. Many die each year from standard gas furnace or hot water heaters. I happen to have electric heat and wh in our home. My brother in law had a den that was added on but, but was unheated. He actually used one of these propane heaters to heat the den and never had a problem. I have a carbon monoxide and smoke detector and have tried the propane heater for several hours and had no alert from the detector. I use this heater for my garage and have never had a problem. There great for back up heat.
A lot.
We have a natural gas fireplace that has no exterior venting. It all depends on whether it's complete combustion (no CO or soot) or incomplete. With a normal gas flame, you want it to be completely blue - no orange or yellow, but I'm not sure how well you can see the flame on the unit in question.
A lot.
The flame is completely blue showing very good combustion.
If the area is totally enclosed it will consume oxygen below 21%. What's the difference if you die from oxygen deficiency or a yellow flame causing carbon monoxide poisoning?
Have some sort of ventilation and use a CO detector. Don't know if they make an O2 monitor for safety.
I have a similar unit. Several fires caused me to lose faith in it. I had an experience lighting it that somehow caused my sleeve to spontaneously combust that still perplexes me, a blow-out that ended up just pumping propane into the air for a few seconds before I shut it off, then determined it wasn't worth the risk.
You are not lighting the heater correctly.
