Yeah I've been pleased with most of their stuff.I have some ratcheting wrenches and a 3/8's socket set. Both well made.
I've got a good mix of tools and they're IMO a decent upper mid-range tool.
I have a lot of ratchets and the Williams in both 3/8 and 1/2 are some of my favorites, the long ones are especially nice, they will make you 20 years younger.Interesting video…it’s defenetly an interesting test methodology but I kind of like the breakdown per price; kind of confirms of what I thought about the mid range priced wratchets; they are built no better sometimes.
The Williams one I’m interested in, I like the construction.
I’m not sure “amazing” is how I would describe it.It’s amazing how much of the tools you can buy in the US is made in Taiwan.
Just out of curiosity, have you tried relubing the SO ratchet? I have an old 1970s vintage SO 1/2" course-tooth ratchet that had heavy back drag. After disassembling and applying Super Lube, it has some of the lowest back drag I have seen.My Williams/SO ratchets have so much back drag that I find them annoying. I’ll probably sell them.
Yes. I soaked them in 0W20 overnight. Wiped off the excess.Just out of curiosity, have you tried relubing the SO ratchet? I have an old 1970s vintage SO 1/2" course-tooth ratchet that had heavy back drag. After disassembling and applying Super Lube, it has some of the lowest back drag I have seen.
I'm surprised they didn't benefit from fresh lube. At least the neighbors were entertained...Yes. I soaked them in 0W20 overnight. Wiped off the excess.
Opened them up, added a small amount of all purpose grease.
Put a socket on them and spun them a few hundred times. I’m sure the neighbors thought I’d lost it, finally.
Very little improvement.
Agree.I’m not sure “amazing” is how I would describe it.
Although, the benefit to the imported tools is they are generally decent quality for the money.
I’ll send pictures in the morning.Which Williams is this? The round heads are very smooth 72t have little back drag and switch very easily.
I agree, there's no point in breaking a tool by intentionally working it well beyond it's limits. If I need a 1/2" ratchet or a breaker bar I grab one.I’ve always oiled my ratchets. And I’m not a fan of breaking tools….like requiring a 3/8 to do the same job as a 1/2.
Overall i like ratchets but, in recent times, I have found myself reaching for the it less and less. Instead I grab the 1/4 or 3/8 breaker bar. As long as I have a clear approach, I break it loose and then flip the tool vertical and use it as a nut runner, without having to switch the socket between tools.I’ve always oiled my ratchets. And I’m not a fan of breaking tools….like requiring a 3/8 to do the same job as a 1/2.
Then clearly you need roto head ratchets. My 1/4" Carlyle is probably my favorite 1/4" ratchet.Overall i like ratchets but, in recent times, I have found myself reaching for the it less and less. Instead I grab the 1/4 or 3/8 breaker bar. As long as I have a clear approach, I break it loose and then flip the tool vertical and use it as a nut runner, without having to switch the socket between tools.
Of course, if clearance is really good I just use the 1/4 impact and finish in a few sec...
The only GearWrench that I own are the SAE and metric ratcheting combination wrenches. I’ve used them on things ranging from my antique Lawn-Boys to removing the top mounting nuts on strut assemblies. No issues whatsoever except for sometimes I miss the offset that regular wrenches have.Gearwrench catches a lot of flak (not sure why) but I like their tools
I have them in all three sizes and, like you, I really like the 1/4. However the breaker has slowly become my favorite, mostly because I am confident that I won't approach its torque limit. But when I can't use the breaker, the rotor ratchet is the tool of choice!Then clearly you need roto head ratchets. My 1/4" Carlyle is probably my favorite 1/4" ratchet.
In 3/8" and 1/2" they get a little too wide for my liking but for some reason 1/4" is great.
Plus if you snap it like I did I love the fact you can walk right in and grab another no questions asked.My 3/8 flex head Pittsburgh Pro is my most used ratchet mainly because of the feel in your hand and the feel of the teeth, not too coarse and not too fine. I pick it over my snap on almost every time. I have been using it for 5 years or more now every day.
Just curious, are the Carlyle versions better than the Pittsburgh Pro versions? I just checked the Napa pricing for them, and they have gone up drastically.I have them in all three sizes and, like you, I really like the 1/4. However the breaker has slowly become my favorite, mostly because I am confident that I won't approach its torque limit. But when I can't use the breaker, the rotor ratchet is the tool of choice!
I havent tried the Carlyle but, based on their other stuff, i would expect it to be a solid product. I own a Snap On 1/4" with the square handle and all sizes of the Pittsburgh which have oval handles. My only complaint for either brand is the handle shape; I dont really like the square, and oval took a while to get used to. Round (like the Carlyle) would be ideal. However, if I were to buy a new one I would probably get a Gearwrench because they have round handles at half the price of Carlyle.Just curious, are the Carlyle versions better than the Pittsburgh Pro versions? I just checked the Napa pricing for them, and they have gone up drastically.
