Originally Posted By: KCJeep
Restricting flow by using louvers (which I am not buying) would only increase stress on the media, not lessen it. A properly flowing filter is likely running just a few psi differential, if you are restricting flow and causing bypass it means the media is hovering around 8-14 psi depending on model. Much MORE stressful on the media, not less.
Kind of ... I think if the louvers were really restrictive the delta-p would be mostly across the metal center core itself, and not the media. The media would have it's own delta-p associated with the flow through the media, and the center tube itself would have it's own delta-p due to the louver restriction. The media and center tube together would make the consolidated delta-p that the bypass valve would see.
I don't think filter manufacturers use louvers to prevent media tearing ... it's more for easier and cheaper manufacturing IMO. Properly formed louvers will flow more total volume due to more flow area than the old hole design.
