PRI-G anybody using it?
Not the same according to them. Ratio is 2000:1, and they claim it cleans fuel systems, will remove and prevent carbon build up, increases mileage, prevents souring of fuel and will revitalize soured fuel into useable condition.
I have been using it for 6yrs and will not use anything else. I use it in 2 trucks, 3 cars , and the 3 outboard motors on my 2 boats. I know about 80 people that use it in their boat engines and will not use anything else. It stabilized the gas in a friend of mines boat for 3yrs. He filled it with gas and added Pri-G in Oct 05. Boat was not started again until Nov 08. Fired right up and he burned out the 120 gals fishing. I know this because he is my neighbor, and I started him using it. Try it and you will never use anything else! I also use it in my lawnmower and weedwhacker. For you boaters, it is the only additive that Sea Tow endorses and uses in their engines.
One observation I have with this stuff is if you spill a little fuel treated with this, it just doesn't seem to dry up. Instead it stays wet, not exacty oily, just wet. And that is at the recommended ratio of 2000:1.
