Pressure washer question.
I have a 4200 psi, 4 gpm pressure washer. Would there be an issue if I was to hook it up to a 4000 psi max surface cleaner. If not getting a 4000 psi surface cleaner I would have to go up to a 4500 psi unit at almost double the price
I don't think that would be an issue. I'd rather have it close to the max rather than over. Otherwise, you're paying for capabilities you can't use.
