Pressure Washer purchase
Music City, TN
Costco has a Karcher with the Honda 6.0 hp engine rated at 2650 psi and 2.6 gpm. It has a 30 ft hose, 5 quick connect nozzles, detergent siphon, and a Karcher commercial grade pump.
Cost is $399. I have no experience with these animals but from what I read this one sounds like a decent value for homeowner use only. I will probably only use it a couple of times a year (primarily to clean exposed aggregate driveway, sidewalk, and porch).
Any recommendations or suggestions?
Why don't you rent a pressure washer to see how they work"so you won't get stuck with one to small.I prefer 3,000 or more psi and 4 gallons per minute. The more gallons per minute the faster the job goes.
I ended up buying the 3000 psi / 2.7 gpm Ryobi with the Subaru/robin 7.0 hp engine that Home Depot is selling for $498. It has a 3 yr warranty through Home Depot and I really liked the non-marking hose and the longer wand with the circular grip.
If you get above 2.5 gal/min can your home water supply even keep up? I know I have a backflow valve on my spigot and I doubt I get more than 2.5 gal/min out of it. Anyone know what 1/2inch home plumbing will put out unrestricted? I'm only asking because my brother used to do cars with a mobile unit and he had a water tank with a 6 gal/min pump going to a 3 gal/min pressure washer so he wouldn't suck the hose dry. I also can't imagine 2200+ psi not being enough. You can cut wood, damage brick, etc at these pressures. There have been industrial accidents resulting in death at these pressures as well. So be careful.
Outlaw Titan - what brand of pump and what kind of oil does it call for (not the engine, the pump)? How soon is it supposed to be swapped?
Just curious - my stock pump oil was smelly and had metal - so I recommend changing early.
P
I will have to check the pump for a brand name but the literature indicates it is a brass pump head with axial cam design and says the it is a maintenance free pump with no oil changes required.
For two uses a year go rent one. You will save money, save space, and leave the problems to someone else.
I considered renting but it costs $60/day to rent a good one and it would take me about 4 days to do all of the projects I need to do this summer. By owning one I can work an hour or two at my convenience and then do another hour or two the next day. Using one of these animals for 4-6 hours would lay me up for at least a week with a bad back. That is precisely why I got one with large cleaning power. The 2200 psi with 2 gpm will clean anything but it just takes longer to do it.
Once you own a pressure washer there is no going back
I guess the pump itself is maintenance free on mine too - but there is gearing for it that takes tractor oil. Naturally I use the Amsoil stuff - and I will say it sure stays cooler. The pump gearbox cooling fins used to get real hot (and as I stated the original oil was kinda nasty)....nothing scientific, though.
quote:
-snip-
I totally agree. I often use my pressure washer to wash down my vehicles (carefully, of course!)- they're great for keeping the undercarriage barnacle-free.
I have the earlier model (2400 PSI) of the Karcher washer, with the Honda engine. I run Mobil 1 10w30 in mine. It's been problem-free and actually kinda fun to use!
