JHZR2
Staff member
I'm making some playground equipment for our backyard, and using galvanized conduit for ladder rungs, a fire pole, etc.
My approach is to drill into wood either through or to a set depth, using a forstener bit, and then after putting the conduit in, drill though the wood and tubing to hold it in place. It makes for some sturdy connections.
All I use is SPAX screws from HD.
I want a tight or even interference fit, but I also don't want to crack the wood with differing expansion and contraction of the wood vs the metal pipe.
So my question is this:
If I drill a 1 1/2 hole in new, wet wood, will the hole get larger as the wood dries and shrinks, or will the hole get smaller since the entire piece of wood is shrinking?
My understanding is that new pressure treated wood (this stuff is wet and sappy) shrinks quite a bit. I saw a recommendation that pressure treated wood decking should be installed with no gap, as the gap will form as the wood dries and shrinks.
If the whole thing will shrink, I'll make the 1 1/2 hole larger than it needs to be by 1/8 or so. The through-bolting will keep it secure in use.
Thanks!
Thanks!
