Originally Posted by wolf_06
Hi folks,
I recently bought a brand new 2018 Mazda 3 GS six speed auto with the 2.0L skyactiv GDI engine.
The owners manual recommend regular octane 87 fuel, but higher grade like 93 can be used.
This topic has probably been on here several times, but is the higher octane would benefit the the 2.0 skyactive engine? Since its a slightly higher compression engine, the manual does not recommend using fuel with a certain % of ethanol in it, not sure exacly how much the %, but here in Canada, gas stations sometime mention "up to 10% ethanol", only shell does not have any.
Should I stick with regular only or go higher grade gas to be safe. Some Mazda forums say the skyactive is design for regular gas, how true this is?
Please share your opinion on this.
Thank you!
I have a 2016 ford fusion and 2018 ford fusion with the 1.5 GDI Turbo Ecoboost engines. The operators manual states that they are designed to use 87 octane fuel but best performance is with 91 octane fuel or higher.
