I'm in a pump oil changing mood/maintenance cycle at work, and am wondering if anyone here knows anything about diffusion pump oil.
This is for mass spec use, and I need-at a minimum-a vacuum in the low 10^-4 torr range, and preferably into 10^-5 torr. I'm dealing with small pumps as such things go-basically pumps for benchtop sized mass specs, which tranlates into a pump about the size of a large coffee cup(typically 20-30mL of oil).
I did one last week with Santovac 5P, which is what Agilent now specs across the board. This was on an older instrument(HP 5971) that said Santovac 5, but the local Agilent FSE said to use 5P anywhere that 5 was previously speced. I originally bought it based just on an Agilent p/n, and paid the frightfully expensive Agilent price of $175 or so for an 18.5mL bottle.
I still need to do an Agilent 5975 and a Varian Saturn 2220, and don't have enough on hand to do both. That means I'm going to need to order SOMETHING. Of course, Agilent is going to follow the company line and tell me to use 6040-0809, which is 5P in an Agilent bottle, and that includes on the Varian instrument also. If I do order more 5P, it will be from a supplier other than Agilent, where I can find the same oil for about half the price
I also need to do a few more foreline(rough) pumps. There again, the recommendation is for Inland 45, which seems as good as anything. The pumps in question are two of the super Varian DS 102s, and the grossly underspecced for the application(but small and quiet) Edwards E2M1.5.
