A lot of it has to do with how the engine is run also. 2-stroke equipment is meant to be run full throttle and up to temperature. If you putt-putt around at idle running 32:1 on any oil, your exhaust ports will be full of carbon and sludge. I've seen it numerous times.I know people still believe that TCW3 will clog exhaust ports and cause (if you have them) power valves to seize up. But what racers have found is that more oil makes more power, and the oil chosen makes a difference with regard to how well the engine runs with a high oil content. 125cc Kart and Motocross guys try all sorts of things for a competitive edge. It was not uncommon to see them switch from thick and gooey Motul 800 and use TCW3 at 16 to 1 with perfect results.
Also it could be that quality TCW3 oils of today uses the very same polybutene base stock as today's EGD oils. The additive package and mix with other base stocks may be different, but it may not matter.
That is a good point, a well tuned 2 stroke running at high power won't clog the muffler, because the EGT is hot enough to burn off the oil deposits. You'll see this on 2 stroke street bikes where they get on the highway, the exhaust heats up and an incredibly acrid fog forms behind. As the oil burns off from inside the expansion chamber and muffler.A lot of it has to do with how the engine is run also. 2-stroke equipment is meant to be run full throttle and up to temperature. If you putt-putt around at idle running 32:1 on any oil, your exhaust ports will be full of carbon and sludge. I've seen it numerous times.
I'll buy that. My last two saw purchases were Husky 562XP and 550XP. Both run max HP around 9,000 rpm and peak at 13,000.A lot of it has to do with how the engine is run also. 2-stroke equipment is meant to be run full throttle and up to temperature. If you putt-putt around at idle running 32:1 on any oil, your exhaust ports will be full of carbon and sludge. I've seen it numerous times.
Those are nice saws! I recently bought a Tsumura 20" bar for my Jonsered CS2255. Definitely lighter than the factory bar and oils better.I'll buy that. My last two saw purchases were Husky 562XP and 550XP. Both run max HP around 9,000 rpm and peak at 13,000.
As mentioned, the pre-mix 50:1 is expensive, but would be perfect for someone using a gallon or two a year.
Yesterday I spent $300 on bars and chains. 18"x.325x.050 for a 45cc Echo, 20"x.325x.058 for the 550XP and 20"x3/8"x.058 for the 562XP.
The 562 had a 28", but it's a pita for firewood gettin'.
For me, 40:1 makes more sense in the high rpm saws than 50:1.
Shell Ultra synthetic and E0 marine 93 gasoline is about a third of the cost of Husqvarna's 50:1 in a gallon can.
Walmart has the oil for $10.50/L, which works out to about $8 USD.
Question: How many of you know how to lube the clutch shaft bearing? Who does it?
Unfortunately Stihl isn't what they used to be. Stihl equipment used to be top of the line (especially their chainsaws), but if you've taken any of the newer ones apart going back 5 years or so, you would know that isn't the case anymore.Echo and Maruyama are both very good brands.However neither of these brands would hold a candle to Stihl in the chainsaw and backpack blower market.Also most of our contractors are now using battery powered hedgecutters and Stihl have the best range and products in the market at present.
The two Japanese brands have always made good line trimmers,but to claim the Stihl FS85,FS94,FS111-131 and FS250 are in any way inferior is just not true.
There are many Husqvarnas I wouldn't buy. I also wouldn't recommend an M-Tronic or AutoTune saw. I'm curious what you consider to be "real data"? It's obvious you are a Stihl fanboy which is fine, everyone has their favorite brands, but to say one brand is way better than all the others is also a big generalization you can't back up. I've had engines apart from all the brands, no one-brand is above the others in my opinion, there are plusses and minuses to all of them.Generalisations will get you nowhere.I have seen no difference in the quality today or yesterday with the commercial products.What has changed are the consumer products and all the other brands also have them.They will not last as long as the more expensive gear.
What has also changed is the introduction of M Tronic with Stihl and Auto Tune with Husqvarna.I will not repair Auto Tune product simply because I am not familiar with them and I would not advise Husqvarna dealers work on Stihl product for the same reason.
Based on jeepmans posts he has always been biased towards Husqvarna product which is fine,but don't criticise others unless you can back it up with real data.To put it in perspective I would surmise that 50% of commercial users in your country use Stihl equipment. Certainly the case in NZ.
The biggest criticism of Stihl I see on BITOG is that you can't buy Stihl parts online.Thanks goodness for that,go Stihl,it's good to hear they are looking after their dealers,the complainers will be the first to get angry when the local dealer shuts down and they have to drive miles to get their gear serviced.work.
