Any of the two stroke racing motor oils will have the highest level of protection.
Like Honda Hp2 or YamalubeR, these are 2 stroke premix oils and not injector oils.
If you need injector oil, Yamaha also has injector oil as does Kawasaki, and there are Dedicated injector oils, Like Belray SI-7.
Non injector 2 stroke oils offer the highest level of protection, but if using in an injector from an oil tank, you need injector oil.
ONe time I ran a 2stroke oil that could be used as injector oil or premix, but I discovered it didnt have the film strength needed for my application.
The HP2 is about the heaviest fim strength Ive seen in premix oil, yamahalubeR is the best cross with Cleanliness and protection. Belray SI 7 is about the cleanist injector oil with Protection.
