Pre luber picture
NY
A few guys asked for a picture of the pre-luber I have hooked up in my van. Under hood pics won't show it, it is buried in the engine bay. The picture is from the brochure I got with the pre-luber. It is over 20 years old, but this is the exact unit, and it works like a champ.
It draws oil from an attachment on the drain plug, and pumps it into the engine where the oil sending unit is attached via a "T" fitting. The oil goes through a filter screen. I have it hooked up to a toggle switch, flip it on before I start the engine and build up oil pressure. This van sat for months at a time w/o starting, so I thought the pre-luber would be a good idea.
It can be hooked up with quick connectors and pump the oil into a container for oil changes, which I don't do that way. It can also pump oil through the engine after you shut the engine off during very hot weather to aid in cooling.
20 years ago my autoshop teacher predicted widespread adoption of variable valve timing and also pre-oilers. so far we have only seen the former. very cool. so what engine and how many miles are on it?
It is hooked up to an 88 E-150 4.9L with only 71,000 miles on it. As you can tell that van did a lot of sitting and saw little use. We'd make trips with it, during the nice weather, it was sort of a mini RV. Now I use it for work, and it is still in mint condition. I actually have another NIB pre-luber which I might use at some future date.
For most cars, this simply is not necessary. It fixes a non problem.
Did anyone note, "Some experts project that the use of this device may extend engine life by as much as 100 times."?
Not a chance.
+1, their add leaves a lot to the imagination, like so many in automotive world do. That luber was installed in 1988 or 1989, and is still in service. As I mentioned the van sat for very long periods of time, and for that reason alone I thought it was worth it. In a daily driver, or even a car used once a week or once a month it would probably be of little benefit today. Oils have evolved greatly in that time.
I still have one NIB, I got a deal on when I bought that one. No need for a daily driver. We were considering it for a Marine application.
Modern synthetic lubricants have helped to decrease startup wear significantly compared to 20 years ago :)
Oh yes, it could be very valuable with different fittings for new engine prelubing.
BTW, when I prelube, I rotate the engine a few rotations while priming the pump or otherwise pressurizing the system.
Not a chance.
When I was going to university, I had access to all of the SAE papers (on microfiche).
There was a paper on a system that looked very much like that shown here.
The paper stated that engine life would be increased 3-5 times by using a pre-oiler.
Still way beyond any "normal" period of ownership, or life of the rest of the car.
Originally Posted By: Shannow
Ha! So did I and spent so much time reading them I almost failed. A fascinating insight to the automotive R&D world.
Shannow - Was that paper concerning start up only, or also keeping pressure when making hard turns, like in autocrossing? [the pick up could suck air sometimes]
