Originally Posted By: slacktide_bitog
Wow, the NOACK difference between Pennzoil Conventional 10w30 and Quaker State Conventional 5w30 is nuts!!!
4.4% vs 11.4!!
GTX isn't that stellar either at 11%.
-snip-
The last two really pushing up on the 15% limit.
They're dino, not synthetic. 11% is fine for a dino. There are full synthetic oils that have higher NOACKs!
"fine" yes, but Pennzoil Conventional's is particularly low, and that's what stands out. Compare it to this 10w30 they also tested:
http://www.pqiamerica.com/June 2014/tLifecycle10W-30.htm
With a NOACK of 12.3%.
Anything below 15% is "fine" but when looking at the numbers, one would generally inclined to lean toward the oils that are the furthest below that limit.
I'd consider ~11% good for any oil, and excellent for conventional.
I think we can put to rest the notion that the fantastic Noack numbers associated with pqia's samples of Pennzoil Conventional in the past were anomalies. This is becoming a consistent thing. Where Noack is concerned, Pennzoil Conventional is just on another level.
