I took my 04 Mercury Marauder out last night and it was 5 degrees out.
When I started the car up it was fine, guess that Amsoil 0W-20 is good stuff.
But the steering wheel was a little hard to turn for a second or so and it made a whine sound. I have Mercon transmission fluid which is speced for the powersteering. I got on the net and Mercon has a pour point of -49 degrees.
I know that Amsoil ATF has a lower pour point, would it be a good idea to put the Amsoil ATF in there in the spring when it gets warmer, or with temps in the single numbers do all powersteering units make noise, maybe they do not like cold weather.
Any thoughts would be appreciated.
