I don't have experience with these speakers but you picked wisely with the NS2 version, 2-ohm. Most nissan's are odd and they use a 2-ohm speaker instead of the standard 4 ohm. I was a little disappointed with the 89db sensitivity, why? Because for every 3 db increase of sensitivity you can cut the audio amp power by half and it'll be the same loudness. Usually factory speakers are around 90-91db in sensitivity. Just letting you know if you're planning on using the factory headunit to drive these speakers. you might have to turn the volume higher for the same loudness.
Other than that, they look like nice speakers, Crutchfield has the NS and the reviews are decent. But I wouldn't use the NS as it's the 4 ohm version but you probably know that. Crutchfield didn't have the ns2.. I liked that they had a rubber surround, foam is a joke, treated cloth only last about 3 years in a car's environment. Seen that over the years. The frequency response was ok 70-20khz, should be decent. I suggest finding a retailer that has a generous return policy in case you hate these speakers once installed.
