Power Steering Pump
Tennessee
I have a 2007 Kia Spectra Ex with 52k on it. The power steering started making a noise when pulling the steering wheel to the extreme left and right. I replaced the power steering pump and bled the link with Kia PSF-3 Fluid. The car is still making the noise. What else could it be beside the belt? Rack and pinion?
Good question........? That would make a noise on any power steering pump vehicle.
Originally Posted By: Kuato
When you say extreme to left and right, are you going to the stops?
Correct as far to the left or right as it turns. I'm wondering if I have a bad pulley or harmonic balancer?
It's probably fine. Any hydraulic steering system will make noise if you put it against the stops...which IMHO should not be done.
