I have a Tacoma that calls for dex 3, I have over sized tires and I've noticed the fluid takes quite a bit of hit between each oil change. By 15k miles the fluid had a burn smell. Ive been checking the fluid condition via the sniff test at each oil change (5k) since and empty the fluid in the reservoir and fill it with fresh fluid. It's been slowly getting coverted to dex 6 which seems to handle the higher temps better as it has less of a burn smell to it. I know putting a cooler is a good idea, and it's on the to do list, but as far as fluid goes I'm thinking about switching to something "full" synthetic. Redline, amsoil, or Royal purple come to mind. Is one of these better than the other? Haven't really been able to much info on it. I guess people are just mostly anal about motor oil. But should I switch is there going to be a compatibility issue with it mixing with dex 6? Will a flush be required or could I just slowly replace it every oil change.
