Recently, our van (2004 Sienna) had a power steering fluid leak, severe enough that the PS fluid tank was empty overnight.
Found out that the leak came from the front of the radiator, the PS lines make a detour over there before coming right back besides the "feeding" line then going back towards the engine compartment. According to the manual's schematics, this is called the PS cooler line. It was rotted out and developed a leak. There is no heat sink around it, just a simple bent steel line.
A mechanic friend told me that he sees this problem quite often and usually simply removes the cooler line and links the two ends together closer to the engine. Since everything is closed for Easter and I don't want to wear out the PS pump prematurely, I did as he said.
Although he said he never had a customer come back for a problem related to PS fluid temp after doing this surgery, do you guys think it's better to spend for a probably expensive new cooler line or can I safely keep driving as-is for years to come ?
