I never mess with my seats, as I just adjust them once and leave it the way it is. But whilst vacuuming the interior of my Grand Marquis this afternoon, I wanted to move the driver's seat forward so I could reach the area under it.
The seat moved forward a bit and stopped. It would neither move forward or backwards, so I was standing there scratching my head, considering I cannot drive with the seat almost glued to the steering wheel. When I push the switch in either direction, I would hear a thump from the motor, but the seat would not move. It was stuck.
I went to get my toolbox, and when I came back, the seat actually moved when I moved the switch. It kept working intermittently (moving a bit then stopping and moving again after you wait for a while), but that thump from the motor is still there when it locked in place. I decided I would blast the seat rails with WD-40, and I only managed to spray the back ends, but have noticed the seat moving faster than it did before.
So I'm thinking there must be some dust/sand and a lack of lubrication on the seat frame causing this issue. If the switch or the motor was the culprit, I don't think the seat would move at all. Just wondering if this would be a correct assumption, or if my motor is going bad.
I am considering pulling the seat out, blasting the rails with some WD-40 to clean them up and then spray some white silicone grease before putting it back in. Thanks!
