Originally Posted By: dailydriver
Originally Posted By: Rock_Hudstone
The weather then turned unusually cold as the days went on, people began, (and still are) searching for gasoline to power generators, if lucky enough to have one. A northeast power outage in November is whole other ballgame compared to the Gulf coast in August, as with Katrina.
Yes, and many of the southerners, and mid-westerners (who usually do not have to contend with Tornadoes in these ambient temps) on here just cannot seem to comprehend that fact.
Do many people have kerosene or propane heaters? I just don't get it, seriously. I have both, including a fireplace, and I live in one of the hottest states in the country. BTW, power outage for a week with 95 degree and hotter weather isn't very tolerable either.
Apartments and condos will not allow for these as there is no way to vent them most of the time. Many also do NOT have fireplaces, and NONE have wood-burning stoves.
As far as what is "tolerable", that somewhat depends on ones physical constitution, and BMI, to a point.
One who has MUCH body fat from excessive beer drinking/over eating/etc. combined with a sedentary lifstyle (I am NOT saying this is you in ANY way, shape or form!) will probably be able to "tolerate" lower constant temps than a very lean/fit person.
Just as that lean/fit person will probably be able to withstand a much higher constant ambient temp than the one with 50%+ body fat.
A kerosene heater only needs fresh air, so a cracked window would suffice. Same with a propane heater.
If I lived in a climate where certain things are necessities for my existence, then preparation should be done to ensure those are met.
What alternative nonelectric methods are available to those in the Northeast for heat? I'm assuming getting "fat" isn't really the answer.
