Hi, new member from the UK
having already made the mistake of refilling and recommending to others a GL-5 oil (Mobilube 1 shc 75w-90) for a manual synchro car geabox that requires GL-4 I thought it best to check -
would Mobilube 1 shc 75w-90 or Castrol Syntrans Multivehicle 75W-90 Fully Synthetic MTF be polyalkylene glycol (PAG)?
I ask as the gearbox is without a drain hole so the existing oil has to be sucked out leaving a lot of it in the box around 25% (0.4 litres of 1.9 litres) and already have seen -
Quote:
beware that there two kinds of synthetic gear available: polyalphaolefin (PAO) based and polyalkylene glycol (PAG) based. PAOs are basically a man made version of mineral oils (although with greatly improved properties) and can therefore be mixed with mineral oils. In fact, semi-synthetic products have mineral and synthetic base fluids in them, so obviously, they must be able to mix. PAGs, on the other hand, will not mix with PAOs or mineral oil. Utmost care must be taken when using this kind of product.
