How about helping build up a data base by answering the following questions:
1) Which restriction gauge?
2) What vehicle and engine?
3) What air filter brand, line (e.g. Fram Tough Guard vs Extra Guard) and if you have a stock airbox or a CAI or some other aftermarket air filtration system (brand and model please)?
4) What was the starting restriction indicated with a new filter? If you installed the unit on a used filter, how many miles were on the filter when you did and what was the restriction?
5) How did you set the indicator? Normally, you do a full bore run to get your initial restriction with a new filter.
6) Generally speaking, what is the environment in which your vehicle operates? Rural and dusty? City and dusty? Very little dust? Wet and clean air, etc?
7) What is the factory FCI on your vehicle?
8) Feel free to add any other info you think relevant, including UOAs or any other data, or even opinions on things that have worked or not worked with regards to restriction indicators.
