- Joined
- Sep 28, 2002
- Messages
- 39,793
I figured that I'd post this here ..since it really isn't a cooling/antifreeze issue per se~ ..but more of a galvanic one.
Will plumbing grade copper handle engine coolant duty? I've got to do some fancy plumbing for some stuff and need to pull some longer straight runs and some 90° and 180° turns and I have a decent supply of 1.5" stock. It simplifies and cleans up a bit of a mess that flex hose alone can cause. Just trying to keep it tidy.
Any help? Now I'm fully prepared for some "you'll shoot your eye out kid!" comments
My gut feeling is that it should work fine. I use LOWTOX, a propylene glycol solution ..and this is used in exchanged systems for solar heating ..but you've got a lot of galanic chemistry going on there, so
I'm not worried about it wearing out. It can always be replaced and I dunno if this is going to be a long term (as in years) installation ..but it may end up being that. If so, then I'll buy the expensive stuff if need be ..but that's not in the budget NOW.
