Rebuilding a transfer case.
Seems this bearing doesn't exist anymore?
Contacted SKF and multiple bearing sellers, nobody really has a clue and I can tell that by seeing how they suggest I buy an improper bearing.
Even with my limited knowledge I can tell they're suggesting something that's clearly not right, I.e. this bearing has a groove for a circlip, and they suggest me a regular bearing without it.
I've kinda figured out a lot of it, just wanted to validate and double check.
6011 ntn9/c3d7vb344
6011 - size
N - snap ring groove
TN9 - Glass fibre reinforced PA66 cage, ball centred (does this still exist? Can't find it anywhere)
Now for the letters after the dash, do they mean anything?
I.e.
C3 - Radial internal clearance greater than Normal
Deep Groove | VB344 Boundary Dimension Deviation
What does D7 mean?
I found a similar bearing, but it doesn't seem to be C3 version, so I'm not sure if it's suitable?
6011nr-skf
Below is the picture of the original I'm replacing.
Would really appreciate some help!
6011 ntn9/c3d7vb344
6011 - size
I.e.
What does D7 mean?
6011nr-skf
