Rather than doing a complete flush then refill--which I do not know how to do (I've read DIY guides but it still looks like more than I can handle at this point, I'm scared!) Would it work if I did a partial drain and refill?
I suppose I can remove as much as I can from the brake fluid and power steering reservoir with a turkey baster and then refill the same amount removed with fresh fluid. This might replenish the system enough until I do it again some 5,000 miles later.
Would this work? What are the pitfalls if any.
