Originally Posted By: BuickGN
I've already given my .02 a bunch of posts up.
In short, while the irridiums may still work at extreme mileages, it doesn't mean they're at their peak performance. I swapped my factory irridiums with platinums at 40K and noticed an improved cold idle. It's going on another 40K and hopefully they now make an irridium plug one heat range colder now so I can go back to them.
I think it's good to swap the plugs at sane intervals because you can see if a cylinder is having problems such as oil burning, lean/rich, detonation, etc. Then there's the danger of stripped aluminum heads with 100K+ intervals.
Be careful swapping iridium plugs for platinum plugs. Platinum has a different electrical resistance and you could be unintentionally putting more stress on the ignition coil(s). If the stock plug was iridium, you want to keep it iridium. It's a good idea (like you posted) to check the plugs at "sane" intervals, but I think replacement should be conditional. Also, Spark Plugs with Trivalent Metal Plating (superior anti-corrosion and anti-seizing properties) make it safe to use plugs up to 110k miles (According to Toyota and NGK).
