Plastic grille crack fix, weld, glue or ???
Take off the grill. Squirt in some gorilla glue on both sides of the crack. Squeeze grill together till it grabs. Wipe off excess. Wait 24hrs. Re-install. Good as new ! YAY :) Note: May take 2 people to help accomplish squeezing the grill and waiting for grab.
Let's just say the old grille trim piece comes off in numerous parts. Not sure if I could afford enough glue...
Uber brittle....,,,No good for glue......I would try E-Bay for a used OEM one. Scrapyards are advertising all over E-Bay. Just got a beauty cover for an 06' Camry 4 banger. I cracked the OE one by accident. Friggin thing looks brand new, and was cheap. Maybe you'll get lucky. At least you know it will fit. :)
I would take the grill out if that's reasonably easy so as to be able to work on the back side. Then fabricate a piece 2 or 3 inches long (probably out of plastic) to fit inside the broken area and epoxy it into place. I've done similar repairs several times and the results have been good.
The original is trashed.
Gotta point there. Keep you occupied. What's that sayin ,,oh, " The idle mind is the devils workshop ".....All jokes aside, please don't trash my idea of snooping around on E-Bay. You just might find a car that was garaged, and was rear-ended. The grill never would have had a chance to get brittle. It's the UV light from the sun that makes them brittle.......... I use to climb around in junkyards, when I was young, like a monkey. Some cars stacked 6 high. The catch was you had to get the part yourself. That was a bummer. You'd be surprised what scrapyard's have. And like I said, it would be OEM. Guaranteed to fit. No worries about a Chinese factory messin up the dimensions.
We got our beloved '06 TSX back today. The chrome grille trim is cracked. I can buy the piece from Amazon for about $50; not sure of fitment.
I can probably get on from Acura, not sure of price.
I've heard of plastic welding but know nothing about it. I believe JB Weld has a plastic version.
What would you do? I appreciate your guidance.
It's really tough to repair these. You could try to use plastic epoxy on the back side as not to ruin the front.
