JHZR2
Staff member
Hi,
I am close to buying a home, which is nice, but has some plaster "delamination" on vertical walls and ceilings.
My parents home was built c. 1921, and has a lot of horsehair in the plaster - its super strong and except for a couple ceilings, no repairs have had to be made. The house Im looking at doessnt have much horsehair content in the plaster, and I think this is why its starting to come off in a couple spots.
So, say you have a spot, say 2ftx2ft that is loose. or say you have a spot where you can see it hanging from the lathing - how do you re-attach?
Must you re-plaster an entire section of wall in order to fix it? The home Im looking at has good ceilings, but if the plaster becomes an issue, its easy to hang sheetrock toi cover the whole thing... but on vertical walls, I have no clue how to fix it,
All of the woodowork is original, not even painted over, its original wood. It is important to me that things stay looking original, and if I want to try to get things fixed before I move in for good... money will be tight, so I have high hopes that I can fix it myself, at least to some extent, prior to bringing a pro in to do the fine work to make it look good.
can you screw up loose palster to the lathing, if its disconnected in a large sheet? I know this seems silly, but if plaster is hard enough and a full sheet, it could be a nice option... no clue if it'd work though.
For spots that are still well attached to the lathing, but has a crack forming, is taping and spackling the best/only solution? Is it a good permanent solution? Id assume taping would stabilize it.
Any ideas or info on repairing would be most excellent.
Thanks for your help!
JMH
JMH
