JHZR2
Staff member
OK, first off, lets get past the silly 'humor' and avoid the comments that "this is Bob is the OIL guy, not Bob is the CEILING guy"... This site has the best set of diversified knowledge on the web...
So, my house has an original enclosed porch... its a late 1920s home. Though it was originally clapboard on the outside, either originally or sometime after, stucco was put on top of rough plaster on the porch walls and ceiling. The stucco on the ceiling is showing cracks and a tad bit of sag in a lot of places. We'd like to install two ceiling fans on the porch anyway, so new boxes need to be put in, so some work will be required no matter what.
A lot of my family live in homes of similar age. I grew up in one. And, I know one thing... most of these houses, in fact, all of them, have porch ceilings that are tongue and groove, stained dark, and shellaced (sp?).
I intend on doing this on mine. So, I need to install tongue and groove as a ceiling. Home Depot sells it in 8' sections (perfect) in pine and oak.
Now, my experience is limited to installing sheetrock ceilings over plaster in my parents' and grandparents' homes. We figure out where the joists are, mark them along their whole length with chalk string, then hold up sheetrock and screw it in along those lines.
But this is a more complex problem... so, should I remove the stucco down to the lathing underneath? If so, I now there will be issues when I get to the plaster corners where the ceiling meets the walls.
If I don't do this, do I want to 'reinforce' the stucco underneath with paster washers or at least some strategically placed drywall screws?
When putting up the tongue and groove, it would look funny to use screws. That isnt how it was installed on the original ceilings in the other homes. Will I want to screw up a series of 1"x8' wood onto the ceiling, for which to nail the tongue and groove into with smaller nails?
Any suggestions or reccomendations of how to perform this install would be most appreciated.
Thanks in advance for the help!
JMH
JMH
