Motor Guard Filter installed 2002 F150 Supercrew. Bracket is a flat piece of steel bent to approx 90 degrees. Removed the plastic battery tray to mount the bracket to steel fender. Heater core line for the supply side and routed the return to a line left around the battery box,under the plastic front shroud to the tee into the bottle line. Truck was an early 2002 with the green coolant so I did a complete flush and went G-05 coolant.
