PF454 Cross Reference without drain back valve
I need a filter thats the same dimensions as the PF454 (clearance issues) that does not have a drain back valve in it
Both Wix and Donaldson sites have sections where you can do an attribute search and narrow down your choices.
It's kind of time consuming, but you'll get some good info there, and then you can easily x-ref to other choices if those brands aren't your cup of tea.
A filter having an ADBV isn't going to hurt anything and can be ran instead of a filter without one.
PF1218 is the longer version of the PF454.
Curious to know if there is a filter without the drainback valve.
Also curious as to why you dont want the valve
