I just acquired a tube of Ultra Slick Brake Lubricant and it has ceramic particles in a carrier of gel-like consistency. Hard to believe but it is actually rated for 2800^F.
Got me wondering if this would work well as a high temp thread sealant. After all a lot of pipe dopes are fine solids suspended in a carrier. I called the Permatex Tech Line but the Rep would only say that it was only designed as a brake lube and should therefore not be used as a thread sealant.
I have been wanting a high temp thread sealant for a long time and the highest temp rating I could find was 600^F. High temp thread sealants would come in useful if you had to make up a threaded pipe joint first and then had to solder or braze next to it.
