OCI was neglected by previous owner. (Maybe never changed.) Oil on the dipstick looked like asphalt. I had the oil changed and drove a few hundred miles and had it changed again. This is the first analysis on this engine.
This truck had no air filter in it.
Local independent oil change facility put this oil in so I am unsure if it is Penzoil, but that was the name on the sticker.
Short trips.
I will do Auto-RX after a couple more flushes with SuperTech 15W-40 & ST Oil Filter.
Oil Report
Blackstone comments: "Nothing too unusual showed up in this sample from your 95 F150. Wear levels read about average, or perhaps a little higher when you look at the wear rate per mile. Universal averages show wear from this type of engine after about 3300 mi on the oil. We did find a little fuel dilution. This level is not more than you can get from city driving/idling, so we do not think it is a mojor problem. This oil doesn't look bad, for being neglected. Check back to establish trends."
[ November 19, 2004, 11:26 AM: Message edited by: rugerman1 ]
Short trips.
Oil Report
