Originally Posted By: juggernaut
Not a lot data around in relation to the Penrite Racing oils when I was recently looking.
Anyway I took the leap of faith and recently serviced the twin 8.1 Mercruisers in my boat with the Penrite Racing 15 as I wanted a "shear free" oil - so far so good although the proof will be when I have a UOA done next year.
While the mechanics of a marine engine are no different from automotive engines (And in many cases are near identical.) What is relevant is how the engines are used and (especially in salt water environments) the increased corrosion potential.
Since marine engines often operate at moderate to high static loads and RPM for long durations (similar to aviation piston engines,) as opposed to the typical dynamic low loads, low rpm and idle conditions that the vast majority of automotive engines experience. Special consideration must be given to the oil chemistry. 10/10ths is a good choices as it is unlikely to shear, but depending on where you store your boat (trailer / on water / ...,_ or how many hours you do on it. The moderate TBN and limited Anti-Ox / Anti Corrosion pack may simply not prove sufficient protection over a 12-month drain interval. This is especially important in your case, as the Ester component in 10/10ths will want to draw moisture out of the air (not good if you're on the water all the time.) THis is of enven more concern if the engine will sit cold on the water for long periods of time, if you're using it regularly then moisture will flash off, but salt can still prove problematic. Marine specific oils are more closely related to off-highway heavy duty diesel oils (than typical automotive oils) which must last a long time and operate at high static loads, with little consideration given to EPA requirements.
I'm not saying it wont work, it's a great oil, and will take a beating, but it's worth keeping an eye on it.
Regards
Jordan
