corrosion off aluminum. I recently bought a brand new 4-stroke model engine that had been in storage for about 25 years. The engine has never been fueled but the exterior of the aluminum alloy engine case had light corrosion; the gentleman I bought from was from a northern state. Anyway, I popped open the valve cover and put a little PU on rocker arms and down the push-rod tubes, some spilled onto the case. I wrapped it up in plastic and put it away. Meanwhile, I did alot research on how to safely clean off corrosion on aluminum and finally decided it was going to need to be bead blasted. Fast forward a week to today, I took it out to get it ready for cleaning and began wiping off the excess oil on the case. When I noticed the corrosion that was marring the finish came right off with each wipe, leaving a clean metallic appearance.
I hope this story/discovery will help someone. I realize this ability to remove corrosion may not be unique to PU, just a property of motor oil but I have never heard of this before.
Anyone have similar experience or knowledge about this?
