My local Ace Hardware has it on the shelf
Probably because they can make a heavier grade oil into a 10w30 from group II stocks without using too much viscosity modifier. For the 5w30 grade they probably need to add some more thermally stable Group III base stocks to get the viscosity index needed.That doesn’t explain why 10w30 and 10W-40 don’t say syn blend on the bottle but 5w30 does. Might it be true?
Must have something to do with the French on the jug. 5w30 all says syn blend here.Of course posting 9 shows a 5w30 synthetic blend and a 5w30 with nothing noted.![]()
That's one of the reasons why I use 5w30 High Mileage blend instead of 10w30 High Mileage conventional. I assume the 5w30 High Mileage blend has better based oils, plus likely less wear at cold start.Probably because they can make a heavier grade oil into a 10w30 from group II stocks without using too much viscosity modifier. For the 5w30 grade they probably need to add some more thermally stable Group III base stocks to get the viscosity index needed.
I assume you're asking about Chevron Supreme? Here is the spec sheet.Is Chevron 20w-50 A Conventional or Sem-syn? Its SN rated....
That’s on the ESI gear oil and HDEO as well …The only Chevron oil I've seen in last 20 years said ISOSYN on the bottle, which an Oreilly store manager told me is Chevron's brand trademark name for synthetic blend. Am I missing something?
Also Quaker State still offers conventional.The good ol’ yellow labeled bottle.
There’s a few other companies that still make conventional oil like Castrol, Chevron, Shell, and Valvoline to name a few. It’s becoming harder and harder to find.
ISOSYN is mostly just a branding name, but Chevron ISOSYN products typically use Chevron base stocks that are refined to a level in between Group II and Group III so are usually referred to as Group II+. Usually, the term "semi-synthetic" means that some percentage of the base stocks used in an oil are Group III. If a bottle of Chevron oil says "semi-synthetic" on the label, you can be pretty sure it does have some Group III in it. If it doesn't say semi-synthetic but is labeled as ISOSYN, then some or all of the base stocks used will be Group II+.Also Quaker State still offers conventional.
Does Chevron still offer conventional? If it says ISOSYN on the bottle that means it's a synblend, at least according to the manager at my local Oreillys.
I didn't think any company still offered conventional motor oil, but fun fact.. Tonight I noticed on Pennzoil website that Pennzoil still offers a conventional oil in a few viscosities.
How much consumption did you have with chevron vs maxlife and at what intervals?I should add that in my experience trying 5w30 Chevron Supreme with ISOSYN technology, it was a bit thin for a 5w30 and my oil consumption signifigantly increased (compared to Valvoline MaxLife Full Synthetic 5w30).
Valvoline MaxLife Synthetic Blend 5w30 (red bottle) slowed my oil consumption a lot (compared to Valvoline MaxLife Full Synthetic 5w30).
So IME, Maxlife Blend is a good choice for oil consuming (burning or leaking) cars. I assume (based on data sheets) that Pennzoil High Mileage and Quaker State High Mileage would be even better than Maxlife Blend for reducing oil consumption. I don't know if those lubricate or clean as well as Maxlife Blend, but I think they're pretty good enough.
Valvoline MaxLife Synthetic Blend 5w30 has more syn, less conv.
Valvoline MaxLife Synthetic Blend 10w30 has less syn, more conv.
5w30 Pennzoil High Mileage is a blend with some syn in it.
10w30 Pennzoil High Mileage is conv.
5w30 Quaker State High Mileage is a blend with some syn in it.
10w30 Quaker State High Mileage is conv.
5w30 Oreilly High Mileage is a blend with some syn in it.
10w30 Oreilly High Mileage is conv.
I've read that Supertech also offers conventional oil and High Mileage oil. Maybe also blend? I don't know if Supertech offers High Mileage conventional or High Mileage blend. I don't know much about Supertech. Hopefully someone will explain the Supertech choices that are relevant.
I don't remember the exact details of amount of oil usage of Chevron Supreme vs Maxlife, but I do remember it was a noticeable difference. It was years ago.How much consumption did you have with chevron vs maxlife and at what intervals?
I emailed chevron a few years back and they let me know chevron supreme 5w30 contained over 40% synthetic base stock.
When you say maxlife cleans, which areas of the engine does it claim to clean?
