Pegasus gas engine oil?
Chicago
Pegasus and other LNG engine oil, what is the difference with this oil? On the surface looking at CST numbers looks like regular 15W40 HDEO.
I would imagine it doesn't have nearly as much dispersant as HDEO, since LNG burns much cleaner than diesel. I don't expect it has as high a TBN since LNG doesn't contain as much sulfur as diesel. Additives to protect against fuel dilution are also probably not necessary. Bottom line - you can probably use 15W40 HDEO in a LPG engine, but I wouldn't use LPG engine oil in a diesel.
This is slight off topic but can you point us to the corect topic link where we can dicuss about Waukesha VHP 890 KW Natural Gas Engines and mechanical / Oil related questions ? Thanks in Advance!
